Civil 3D Forum
Importing GIS Maps
8 REPLIES 8
Message 1 of 9
htr_anderson
479 Views, 8 Replies
Importing GIS Maps
What is the easiest way to import an areal photo into civil 3d to overlay onto a cad drawing
8 REPLIES 8
Message 2 of 9
"Mapiinsert"  if you have the world file.
Jeff
Civil 3D 2024
Message 3 of 9
what if I just had a jpeg?
Message 4 of 9
Use Raster Design and the Rubber Sheet command to collate the image. A uniform grid of points works the best. Otherwise the image will be distorted.
The image can them be saved with a World File.
Jim
Matrix3DSurveys
Message 5 of 9
If the image is not geo-referenced - Old school Autocad.... insert image, scale move and rotate. just set the image display order to the back and line it up the best you can.
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 6 of 9
Geomap worked great for the computer, but I need to be able to print it with the CAD linework and symbology, as well as the map image underneath which does not plot with the linework. How can I get both?
Message 7 of 9
antoniovinci
in reply to: htr_anderson
If you have only a simple JPG (not a georeferenced JPEG2000), you may place it according 2 points of known coordinates, thru the _ALIGN command.
Finally you make the worldfile by means of this free tool: http://www.cadstudio.cz/georefimg
Message 8 of 9
htr_anderson
in reply to: antoniovinci
It will be georeferenced, I'm just waiting to get it from another department...There is no way to plot with the geomap background?
Message 9 of 9
neilyj666
If you are using 2015 then aerial imagery is available OOTB and it can be plotted from a layout. It is not officially plottable in any earlier release.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
