We have been trying to import points from a text file in Civil 3D 2008 and was only successful once. The format is: PointNumber, DECDEG Lat, DECDEG Long, PointElev. In setting up the format we use the Coordinate zone transform MI83-SIF. After setting the format, we load the txt file and Parse it and it looks fine in the Point File Format dialog.
We then start a new drawing and try to import the file and we get the "a non-LL coordinate zone must be set..." error. Then on the prospectus for the drawing (Drawing1) we edit the drawing settings and set the same zone. After setting the dawing zone we try to import again and the "a non-LL coordinate zone..." error is replaced with "no points were transferred from the source" error. We tried different settings under the "Transformation" tab of the Drawing Settings (namely just the two check boxes "Apply transform settings" and "Apply sea level scale factor") and no luck. We also tried to change some settings under the Point Feature Settings (i.e. Allow Checked-In Points to be Modified set to True). But we get the "no points were transferred..." error every time -- except once, but I don't know why.
What are we missing? We are able to import the file using LDD Companion 2008 (which we now do as a work-around), but can't figure out why it doesn't work under Civl 3D.
Thanks in advance.
<WadeN> wrote in message
href="news:6166075@discussion.autodesk.com">news:6166075@discussion.autodesk.com...
We then start a new
in advance.
Thanks Nourinho. I've tried everything and, at the end, my problem it was ID = 0...
