AutoCAD Civil 3D General Discussion
Distinguished Contributor
MtnMax700
Message 1 of 7 (780 Views)
Importing Coordinates & No point file format match found
780 Views, 6 Replies
02-28-2013 12:23 PM
I am tryiny to import coordinate file like I have so many times and the Select File box keeps telling me "No point file format match found".  I click the proper file format and it shows in the Preview box but the OK box will not go dark so I can clcik on it.   The file is a CSv and tried making it a txt with no luck.   Using 2012.
Ideas?
thxs.
David
*Expert Elite*
neilyj
Message 2 of 7 (777 Views)
Re: Importing Coordinates & No point file format match found
02-28-2013 12:27 PM in reply to: MtnMax700
I've had this before - make sure you don't have an extra blank line at the end of the file.
Can you post the file for someone to look at??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
*Expert Elite*
AllenJessup
Message 3 of 7 (773 Views)
02-28-2013 12:53 PM in reply to: MtnMax700
Also make sure that you don't have file format filtering turned on.
MtnMax700
Message 4 of 7 (757 Views)
02-28-2013 01:42 PM in reply to: AllenJessup
No blank line.
file formatfiltering will not be on until I pick the file.  Then turns itself on.  Try selecting right format(PNEZD, comma deliminated) first but filtering still turns itself on.
Thxs.
David
*Expert Elite*
neilyj
Message 5 of 7 (754 Views)
02-28-2013 01:46 PM in reply to: MtnMax700
Best post the file?
neilyj
*Expert Elite*
AllenJessup
Message 6 of 7 (752 Views)
02-28-2013 01:49 PM in reply to: MtnMax700
Yes when you pick the file it turns on. You still should be able to turn it off. However if it says it can't match the file format after you select the file then It's finding something it's not expecting.
If you can't post the whole file maybe you could post the first and last 5 of 10 lines. That might give us a clue.
MtnMax700
Message 7 of 7 (749 Views)
02-28-2013 01:54 PM in reply to: MtnMax700
Finally figured it out.  One point had a name-not a number.  I've had this before and it gave me an error message but still imported the file.
Thxs. for your help.
David
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
