Civil 3D Forum
Importing a Google Earth Surface
7 REPLIES 7
Message 1 of 8
yogesh_mundhe
2007 Views, 7 Replies
I am facing an issue while importing a google earth surface, while impoprting i have to restart a GE everytime otherwise it while imorting it comes up to 49% and then stop working,
Why this is happening...is there any solution?
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: yogesh_mundhe
Go to Toolspace, Settings, Surface, Commands, ImportGEData and ImportGESurface
Right click each of these, under the Google Earth Options change the Rows & Columns to be 70 x 70 or less.
Jeff_M, also a frequent Swamper
Message 3 of 8
yogesh_mundhe
in reply to: Jeff_M
I did that settings also...But d issue is that ..it works only once....after importing a surface I need to restart a GE in order to import a next surface.
Message 4 of 8
Jeff_M
Correct, GE only allows a certain amount of data per session. If you find an older version of GE, it used to allow much more data (version 4.2, I believe, was the last to do so).
Message 5 of 8
yogesh_mundhe
in reply to: Jeff_M
Jeff ...thanks a lot for your reply.
I had tested on GE 5 & GE 6...both have d same issue.
Message 6 of 8
You might be interested in our software, Plex.Earth, which deals with this issue, by identifying when GE reaches to that state. It prompts you to close Google Earth and then it resumes the procedure from the last point.
If you want to parse hundreds of thousands or millions points from GE , there's also a special edition which fully automates the procedure.
You can test it from here:
http://www.plexscape.com
BTW, if you work on AutoCAD 2012, it's also available throught the Autodesk Exchange App Store.
I hope it helps and if you need anything, please let me know.
Best regards,
- Lambros
Message 7 of 8
Thank U... Lambros
Will check out that.
Message 8 of 8
Thanks! Let me know for anything you need.
- Lambros
Rail Community
