Civil 3D Forum
Importing a DEM/adf file
4 REPLIES 4
919 Views, 4 Replies
Each time I attempt to import a USGS .adf file the program becomes un-responsive and locks up
approx 450,000KB in size
Any solutions?
4 REPLIES 4
antoniovinci
tprawel wrote:
Any solutions?
Convert it to Geotiff format thru a free tool like Qgis, sir.
And import it how? Will it be converted to a tiff? I need to model it?
Timothy P. Prawel
Daigler Engineering, PC
1711 Grand Island Boulevard
Grand Island, New York 14072
(716) 773-6872, ext. 208
tim@jadenvegr.com
Joe-Bouza
when you pick the tiff c3d will do the majic
Joe Bouza
Neilw_05
What is your OS and system specs? You'll need at least 8GB ram and 64 bit OS.
Also, consider reducing the area of coverage by applying a data clip boundary. That way you can reduce processing. Once you get a surface built you can adjust the clip boundary if you need to expand the coverage or limit it to different areas. You could also make multiple surfaces from the source file, each covering different areas using clip boundaries.
I don't know if using a GeoTiff would reduce the processing requirements as it should have the same amount of data.
What do you say Antonio?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Rail Community
