I've worked through creating Pressure Pipe fittings from STEP files provided by a vendor, but when I try to create a network with my new parts, nothing appears or is added to my prospector. AutoCAD acts like it created pipes and fittings (no error messages) but nothing is drawn or added to the network.
If I set to one of the provided AWWA catalogs and create a network from my Pline, I get pipes.
What gives? What step or setting am I missing that makes my new catalog create null, empty or blank objects?
Thanks (again).
Solved! Simple typo. I was using a quote mark for my descriptions in Content Catalog Editor and that was throwing it off. Use two single quotes for inch marks in all your descriptions.
Solution was found in this Autodesk University Online class. This is a very good discussion on building Pressure Pipe networks:
