I just noticed that when I did an import of styles from my 2014 template into a new, blank 2015 template (using Manage>Import Styles) that Point Description Key Sets aren't transferred. Is this intended behavior or just a bug?
Pretty sure this is the intended behavior as Description Keys haven't imported using Import Styles in previous releases either AFAIK.
Description Keys can be copied dwg to dwg in Master View or inserted as a block into the dwg.
It has behaved this way for quite some time. At least from C3D11- as best as I can remember. Not exactly sure why, it imports point styles but not the description keys. You would have thought that it would be a simple thing to import them since they fall under the same tree in the settings.
Rick Jackson
Survey CAD Technician VI
