We are using Trimble Access to collect data in the field and each point has multiple attributes. I then process it in TBC and get a shapefile with all the data I need in it. I can get the shp file in Civil 3d multiple ways, but I can't figure out how to load it into my survey database so I can process linework.
How do I get a point shp file into my survey database?
The Survey Database will take the points in PNEZD (.TXT or .CSV) format or from an Autodesk Fieldbook file (.FBK).
The Fieldbook file allows linework processing from Point Descriptiors.
If you can get the data exported into one of those formats you should be good to go, but most likely you won't have all the other point attributes (multiple descriptions).
>> Edit
There is also Survey Extended Properties which can be read from a Survey LandXML file whcih would aid in keeping additional data withthe points. But I've never converted from SHP to LandXML and am not sure that Trimble will either.
Have you just tried the _MAPIMPORT command..?
Is there some way to bring the shp files into C3D and then kick them back out so the attribute titles will be in the csv?
Code name Northing Easting Elevation Feature Surface Mateial Comments
Edge of road 5000 5000 100 ER asphalt S 8th ST
Code name Northing Easting Elevation Feature TYPE Comments
Breakline 5010 5010 100 BL Toe of Bank 8' flat btm ditch
Code name Northing Easting Elevation Feature TYPE Surface Mateial Comments
Bridge 5020 5000 100 BRGE HWY aphalt S 8th ST
My problem with exporting out to a csv file is that all of my codes don't have the same attributes, or even the same number of attributes.
_mapimport gets my point data in, but I'm still not sure how to get it back to the suvey data base for processing
One way is to make a block with attributes and use it during MAPIMPORT. Map the shape file's DBF fields to the attributes. Then do a DATAEXTRACTION from AutoCAD to a CSV file.
Mike
Once you get your data in to a CSV file. You can create a User-Defined Property to import the points with additional descriptions.
Allen
Allen Jessup
CAD Manager - Designer
UDP will not work because depending on the code the attributes will change, so sometime you will have up to 10 attributes, but more importantly the attributes are not always in the same order.
Making a block everytime I have to process data does not sound very stream lined.
That's not good. You can certainly use Map to get in points with multiple attributes. But I don't see how you'll ever get them in the Survey Database. Hopefully someone else will have a solution.
Allen
Allen Jessup
We are also using Trimble to capture point attributes. We are using a custom program developed by Adam Koerner of CAD Artisans (now Civil 3D Power Tools) that converts the survey data to XML, where we can import this into the survey database.
This program was developed by Adam for the British Columbia MoT, and is proprietary, as we have not been able to accomplish importing points with data into the survey database easily.
I would suggest you contact Adam to see if he can be of help (sales@civil3dpowertools.com)
Keith Biggs
Chair, CAD Committee & Senior CAD Technician
R.F. Binnie & Associates Ltd.Leading in Quality: OQM Certified March 2013.
Just make generic attributes in the UDP.. like att1, att2, att3, att4.. etc.. then create an import format and process... the import format can be saved in your template. You know what attributes are which with each feature, so then you can make point groups in your templates that represent the features and can label the attributes with the attribute titles.
For instance for a Tree point group, make a tree label style w/ Tree Size = <att2> Tree Species = <att5> etc..
That's what we do anyway and it works well. We can use the field to finish while keeping all the attributes collected with the Trimble FXL...
Nate
