Distinguished Contributor
alb01
Message 1 of 6 (220 Views)
Import Microdrainage - Parts list missing
220 Views, 5 Replies
07-17-2013 06:40 AM
I have created a drainage network in Civils 3d and exported it to WinDes Mircrodrainage.  Once i completed the drainage design i.e. invert levels etc i clicked 'project export' and saved as a FWS file.
When I return to Civils 3D and import the microdrainage - see attachement the part list pull down menu is empty.  any ideas?
I have labelled the pipes using the microdrainage numbering tool, i have part lists in exisitance (i found them in the setting tab of the tool box.
New Member
OwenPro
Message 2 of 6 (122 Views)
Re: Import Microdrainage - Parts list missing
02-19-2014 01:25 AM in reply to: alb01
Alb,
I too am having this same issue. Did you ever find a solution?
Owen
Member
Toby_Nicks
Message 3 of 6 (116 Views)
02-19-2014 01:46 AM in reply to: OwenPro
Hi both,
Have you checked that the pipe catalogue is defined in home>create design>set pipe network catalogue? And that you've created a network parts list which is also defined in the network properties?
I've been using the WinDES imports for a little while now and it does have it's issues but I've not come across this particular problem?
Cheers,
Toby
New Member
OwenPro
Message 4 of 6 (109 Views)
02-19-2014 04:11 AM in reply to: Toby_Nicks
Thanks for the quick reply Toby, I tried your advice but it was to no avail.
To clarify, I am using Civil 3D 2014. The solution/workaround I found, was to open up my drawing in Civil 3D 2013, where the command works just as it should.
I assume the Autodesk guys (Jack Strongitharm, I'm looking at you), are still working on it for 2014.
Member
Toby_Nicks
Message 5 of 6 (103 Views)
02-19-2014 04:46 AM in reply to: OwenPro
Should have mentioned I'm using 2013!
I was hoping they would have fixed the various bugs which have popped up rather than creating new ones...
Cheers,
Toby
alb01
Message 6 of 6 (92 Views)
02-20-2014 05:20 AM in reply to: Toby_Nicks
Hi Guys,
looks as if this still hasen't been resolved for 2014. I will still leave as active
