I would like to be able to import LDT point groups into a C3D 2015 dwg. Is it possible to import the Groups.mdb file into C3D? Is ther another way that would be easier?
Solved by AEC_Cadd. Go to Solution.
A,
Groups? No, I don't think so. Points and Description Keys, but not Point Groups.
Dave
Dave Stoll
Las Vegas, Nevada
Can you export the point groups out to a LandXML file and then import that?
Not sure, just guessing.
I don't have a LDT project to test with, but didn't the old Import Land Desktop project command include point groups? The command still exists in 2014, is it available in 2015?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I just tried that using LDT 2009. I picked the option to add point groups to the XML and 3 were added. When I imported that XML into C3D 2015, the point groups were not included. Was worth a try, I appreciate the suggestion.
Check the Civil 3D App store 🙂
I wrote a utility that does it.
