Civil 3D Forum
Import LandXML Dialog Box Does Not Open
3 REPLIES 3
Kenneth_L
874 Views, 3 Replies
I am trying to import a LandXML surface into my project.  However, when I click the "LandXML" button in the "Import" tab, absolutely nothing happens.  The command _AeccLandXMLIn appears in the command line, but there is no dialog box and no further action from Civil3D.  Any ideas how I can get this to work?
I ran into a similar problem with the normal "Open File" dialog box, and had to run a FILEDIA command to turn that dialog box back on.  Is there a command like that to turn on and off the Import LandXML dialog box?
Thanks for any help you can offer.
3 REPLIES 3
gsisman
in reply to: Kenneth_L
I have the exact same problem but I see this message in the command line after pressing the menu choice on the File/Import/LandXML option
 _AeccLandXMLIn Unknown command "AECCLANDXMLIN".  Press F1 for help.
BradPowell
Its opening off the screen. Start command and then press ALT+Space+M and hold your left or right arrow keys down until box appears.
r.capper
in reply to: BradPowell
It is offscreen, faster than move.
Start command and then Try [windows key]+ left/right arrow several times until appears, will cycle it between screens.
How bizarre, that dialog behaves like a separate window but isn't exposed in Alt+tab!
Robin Capper
Design Systems Manager
LDE Ltd
Rail Community
