Is there a easy way to import kml/kmz file to autocad c3d
I have read all the previous but unable to got a solution
try this:
http://tbn2.blogspot.com/2008/04/expge.html
expge -> autocad entities to kml
readkml -> kml to autocad entities
or this:
http://tbn2.blogspot.com/2011/02/programas-tbn2.html
expge2 -> autocad entities to kml
readkml2 -> kml to autocad entities
(more faster)
To import KML files to autoCAD:
http://tbn2net.appspot.com/showprog?progid=READKML2
To export AutoCAD entities to Google Earth KML files:
To import elevaions from Google Maps to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=IMPORTGMPTS
To import maps from Google Maps to AutoCAD:
Your post reads 2011. Whats the issue? 2011 have the ability on the insert tab>>> goole earth
Your Name
Your Name
KML file - not a surface, not a mesh, not a photo. The points and route with point numbers and attached info
. How do you import a kml file..?
neilyj (No connection with Autodesk other than using the products in the real world)
I recently had to do this. Best way I found was converting the KML to SHP in Qgis then importing the SHP file. Other than that, I would love to hear other suggestions.
If you know how to use Map3d Data Connections and FDO then you can install the SL-King KML FDO provider.
I've only once had to import a .kmz file, not a very common filetype in my opinion. We don't use .kmz because it's Google only, and licenses to Google Earth are super expensive. My old office only had two guys with Google Earth, one was in marketing and the other was a landscape architect. It's not really an engineering tool.
The .kmz I have looks like it was originally drawn in microstation, maybe try importing using microstation and saving to dxf and opening with C3D.
NoelNicholls7434: ... have third party software in ExpertGPS. But was looking to have a direct import. ...
Third party does not mean running outside of CAD. All of our products run inside the CAD engine (in this case Civil3D). You choose the tool from a ribbon panel integrated with the others. After selecting multiple files the geometry appears immediately inside your current drawing. We can't imagine a more direct way.
csevers: ... licenses to Google Earth are super expensive ...
Not any more now that Google Earth Pro is free.
Oh, I wasn't aware. That must be pretty recent, like within the last year or so. I'm going to have to DL Google Earth Pro and take a looksee at ExpertGPS.
The Gizmo tool certainly does what it says on the tin - fully integrated into the ribbon and import kml/kmz/gpx etc etc with no problem
