Civil 3D Forum
Import KML/KMZ file to c3d 2011
19 REPLIES 19
Message 1 of 20
arshadmirza786
5426 Views, 19 Replies
Is there a easy way to import kml/kmz file to autocad c3d
I have read all the previous but unable to got a solution
19 REPLIES 19
Message 2 of 20
Izaiasmai
in reply to: arshadmirza786
try this:
http://tbn2.blogspot.com/2008/04/expge.html
expge ->  autocad entities to kml
readkml -> kml to autocad entities
or this:
http://tbn2.blogspot.com/2011/02/programas-tbn2.html
expge2 ->  autocad entities to kml
readkml2 -> kml to autocad entities
(more faster)
Message 3 of 20
neyton_
in reply to: Izaiasmai
To import KML files to autoCAD:
http://tbn2net.appspot.com/showprog?progid=READKML2
To export AutoCAD entities to Google Earth KML files:
To import elevaions from Google Maps to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=IMPORTGMPTS
To import maps from Google Maps to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=IMPORTGMMAP
Message 4 of 20
Joe-Bouza
Your post reads 2011. Whats the issue? 2011 have the ability on the insert tab>>> goole earth
Your Name
Your Name
Message 5 of 20
KML file - not a surface, not a mesh, not a photo. The points and route with point numbers and attached info
. How do you import a kml file..?
Message 6 of 20
If you were to consider third party software, take a look at Gizmo3D which will import Google Earth KMZ/KML Files as well as numerous other formats.
Message 7 of 20
Already have third party software in ExpertGPS. But was looking to have a direct import.
Supposedly we move to 2015 next month, that is supposed to do the import in Map.
Noel Nicholls, R.P.L.S. | Land Surveyor
Pape-Dawson Engineers, Inc.
TBPE, Firm Registration # 470 | TBPLS, Firm Registration # 10028800
2000 NW Loop 410, San Antonio, TX 78213
P: 210.375.9000 | E: NNicholls@pape-dawson.com
CONFIDENTIALITY NOTICE
This electronic mail transmission may be confidential, may be privileged, and should be read or retained only by the intended recipient.
If you have received this transmission in error, please immediately notify the sender and delete it from your system.
Message 8 of 20
Not sure that it does but willing to be proved wrong.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 20
csevers
in reply to: NoelNicholls7434
I recently had to do this. Best way I found was converting the KML to SHP in Qgis then importing the SHP file. Other than that, I would love to hear other suggestions.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
Message 10 of 20
Murph_Map
in reply to: csevers
If you know how to use Map3d Data Connections and FDO then you can install the SL-King KML FDO provider
Murph
Supporting the troops daily.
Message 11 of 20
You can certainly export to KML in 2015 but a direct import is omitted
Message 12 of 20
Thanks Neilyj,
Since you are rated "Advisor" please do not take this personally - it is directed at the "Borg".....
And just why would AutoCad map 'omit' (?) the ability to import something that major?
In probably the most widely used drafting system...
Freely passed around in geocaching, sailing, etc. a kmz or kml is capable of conveying data clearly to the general public.
And to be used by the general public.
Is this some lawsuit thing ?, or are they once again trying to piss off annoy land surveyors?
I can think of few things that help a non-surveyor picture a property better than a kml boundary outline viewed in Google Earth.
And just received from another survey company a kml of points and route that I have to convert to get into Civil 3D
This is insane in 2015.
Message 13 of 20
I've no idea why there is no direct import as I'm not aware that kml/kmz is a proprietary format.
Unless there is something in the upcoming 2016 release it is third party solutions only
Message 14 of 20
Obviously above our pay grade....
Message 15 of 20
csevers
I've only once had to import a .kmz file, not a very common filetype in my opinion. We don't use .kmz because it's Google only, and licenses to Google Earth are super expensive. My old office only had two guys with Google Earth, one was in marketing and the other was a landscape architect. It's not really an engineering tool.
The .kmz I have looks like it was originally drawn in microstation, maybe try importing using microstation and saving to dxf and opening with C3D.
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Message 16 of 20
NoelNicholls7434: ... have third party software in ExpertGPS. But was looking to have a direct import. ...
Third party does not mean running outside of CAD.  All of our products run inside the CAD engine (in this case Civil3D).  You choose the tool from a ribbon panel integrated with the others.  After selecting multiple files the geometry appears immediately inside your current drawing.  We can't imagine a more direct way.
csevers: ... licenses to Google Earth are super expensive ...
Not any more now that Google Earth Pro is free.
Message 17 of 20
csevers
in reply to: TerryDotson
Oh, I wasn't aware. That must be pretty recent, like within the last year or so. I'm going to have to DL Google Earth Pro and take a looksee at ExpertGPS.
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Message 18 of 20
neilyj666
The Gizmo tool certainly does what it says on the tin - fully integrated into the ribbon and import kml/kmz/gpx etc etc with no problem
Message 19 of 20
neilyj666
Probably within the last month or so it went free - not sure of the advantages yet though
Message 20 of 20
neyton_
in reply to: neilyj666
Rail Community
