marcoarmstrong7258
Message 1 of 6 (2,177 Views)
Import Google Earth Image and Surface
2177 Views, 5 Replies
02-04-2013 12:45 PM
I have no problem bringing my google earth image and surface into autocad civil 3d 2011...but when I do bring it in the elevations are not correct...I'm bringing in a google image that have an island over water.... the units are wrong even though i changes to units in autocad...what do I have to do in order for google earth to import the correct elevation into autocad civil 3d 2011 ?
wfberry
Message 2 of 6 (2,140 Views)
Re: Import Google Earth Image and Surface
02-05-2013 08:19 AM in reply to: marcoarmstrong7258
For starters:
Toolspace->Settings->Units and Zone.   You need an "Available Coordinates System" set here.
Bill
Valued Contributor
gunnarl
Message 3 of 6 (2,128 Views)
02-05-2013 10:39 AM in reply to: wfberry
The INSUNITS setting will affect items imported from google earth. I can't remember what the setting needs to be, but i know leaving it at UNITLESS doesn't bring the items in at the correct scale or elevation. The setting should be Foot, Inches or Meters, i can't remember which one i found works. I'm don't have 2011 or 2012 available right now, otherwise i would check for you.
Active Contributor
w_davis
Message 4 of 6 (2,123 Views)
02-05-2013 11:02 AM in reply to: marcoarmstrong7258
Maybe look in ArcGIS for AutoCAD, it is a free download from the ERIS site and it works great for me, the GIS shows up on my ribbon and I can load a basemap, which is basically Google Earth but as far as elevations go....my discoveries have not brought me an answer yet...
Active Contributor
w_davis
Message 5 of 6 (2,116 Views)
02-05-2013 12:33 PM in reply to: w_davis
**Correction** ESRI
marcoarmstrong7258
Message 6 of 6 (2,095 Views)
02-06-2013 04:40 AM in reply to: marcoarmstrong7258
OK I just recognize that the elevations in Google earth itself are reading crazy..I'm trying to get elevations around a island from a tunnel that goes under water. I also checked the elevations on land and there all reading incorrectly in Google earth itself. Any suggestions?
