lambertb
Message 1 of 7 (343 Views)
import fbk
343 Views, 6 Replies
10-31-2012 10:49 AM
I created a fbk with trimble business center. The fbk is all coordinates. C3D 2012 implys this fbk is all control points.
Is there a way to import a fbk so that c3d reads the points as non-control points?
Is there a way to change the points attributes to non-control?
Is there a toggle in C3D so I can edit multiple points before regenerating the network?
Thanks.
C3D 2014 SP1, Windows 7 Enterprise 64-bit
Dell T3500 workstation, too much ram to post
Distinguished Mentor
rl_jackson
Message 2 of 7 (328 Views)
Re: import fbk
10-31-2012 03:00 PM in reply to: lambertb
Instead just import a ascii text file. Then it wont use the FBK stuff.
C3D12-13
Win7x64 6gb
Valued Mentor
david.zavislan
Message 3 of 7 (311 Views)
Re: import fbk
11-01-2012 08:40 AM in reply to: lambertb
Edit the field book file and change the "NE" or "NEZ" commands to "NE SS".
David Zavislan, P.E. | Wood Rodgers, Inc.
lambertb
Message 4 of 7 (282 Views)
Re: import fbk
11-05-2012 05:39 AM in reply to: rl_jackson
We have and are looking at ascii files but the way c3d reads them with attrubutes has been giving us some problems. When are working on a stylesheet from TBC that will work with c3d. It is not very useful that civil 3d does not seems to allow attribute names to be imported via csv. It seems to only read values.
Our current csv line is similar to
Point,Northing,Easting,Elevation,Code Attribute Value Attribute Value... /Note
Has anyone gotten c3d to read a line similar to
Point,Northing,Easting,Elevation,Code,Note,Attribute Name,Attribute Value,Attribute Name,Attribute Value ...
rl_jackson
Message 5 of 7 (270 Views)
Re: import fbk
11-05-2012 12:57 PM in reply to: lambertb
C3D will not use the additional informatino natively, upon import with out the use of UDP's. Then things just seem to get a little convoluted. I guessing that this may be an equipment function/ collector function - that works well for the DC but is quite burdensome to get into C3D at the moment. Out of curiousity what equipment are you using?
C3D12-13
Win7x64 6gb
lambertb
Message 6 of 7 (263 Views)
Re: import fbk
11-05-2012 01:32 PM in reply to: rl_jackson
We use Trimble collectors and with TBC we can export any format ascii using style sheets. I don't have a good gripe on how c3d can utilize attributes and notes but at this time it seems poor to me when it comes to importing them.
We are trying for the
but I don't think c3d will let us use the attribute name column.
What's a UDP?
rl_jackson
Message 7 of 7 (258 Views)
Re: import fbk
11-05-2012 02:14 PM in reply to: lambertb
UDP? User Defined Propeties
You may also what to look at Survey Extended Properties
This all depends on the Data your trying to Import.
C3D12-13
Win7x64 6gb
