Hello, I am using Carlson survce collector software and c3d 2014. I simple store points ,transfer them in c3d , add some new stake points in c3d , back to the collector again for stake out. I am not using c3d for long time and I have some issues with that'proccedure.here is where I am so far: 1.if I use the Carlson connect and import points from two files for example file one with points 1-15 and file two with points 1-20 , I end up with a DWG file with points from 1-35 and the problem with that is I loose control of my points and what they represent.when I store the point I keep note for example that the point #18 is a specific building corner , but with the c3d import the #18 point becomes 15+18=33 in the above example . I do not use descriptions when I store the points.I thought as a solution to export an ASCII from the survce as P,E,N,Z and then import that in c3d as Raw descr,E,NZ. and with that way I transfer the point number from survce as Raw description in c3d. So the Carlson connect solution is abandoned so far. My first question is can I have more control to the Carlson connect or not? How you guys overcome those problems? 2.when I need to stake out. The new points in c3d have point numbers of course and some descriptions .same problems with the Carlson connect. So again the carlson is abandoned and I export them in P,E,N,Z,D text and import in survce. Question :am I right so far or I am missing something? How you guys work? 3. I did not use database so far. I will use it if I could some how store my points distinguished buy date and work file .is it posible? I mean if I have points from 1-15 in a job to import those as exactly 1-15 in database. I hope I was enough clear for what I am doing and what i want to do.I do not have any experience in c3d or procedures like that. I appreciate any help. Thanks
