Valued Contributor
eladkcem
Message 1 of 2 (663 Views)
Import DGN not mapping linetypes
663 Views, 1 Replies
10-12-2012 11:18 AM
I'm having an issue within the DGNIMPORT command related to a mapping setup that only partially maps..
I'm using the DGNIMPORT command in a nearly empty civil3D drawing. I created a mapping setup to map over the levels to layers, the line styles to linetypes and the lineweights. The levels successfully become layers, the lineweights are mapped appropriately... but the Linetypes are NOT.
I've attached two screen shots to illustrate the issue. The first shows the window with my mapping setup.
The second shows the 'preview' for the setup (Microstation Linestyles 1,6,7 are sent to continuous instead of to the 3 line types I created for the mapping process...)
Any help?
Thanks!
-Dale
I'm using Civil3d 2011 with SP1 and SP2.
Valued Contributor
eladkcem
Message 2 of 2 (602 Views)
Re: Import DGN not mapping linetypes
10-17-2012 02:41 PM in reply to: eladkcem
I figured this one out...
The linetype mapping only looks at linetypes in the acad.lin file. The custom linetypes I had created were in a separate *.lin file. Even though they were available in the drawing, they didn't end up accessible by the actual mapping..
-d
