Civil 3D Forum
Import data from LD
2 REPLIES 2
Buzz12345
126 Views, 2 Replies
Import data from LD
I've encountered the following error while importing data from a LD2005 project:
Error during Surfaces migration!
Please note:
plSurface->ImportTIN(J:\Land Projects R2\...\dtm\NG2000\NG2000.tin) failed!
Horizontal Alignments migration completed!
Profiles migration completed!
Please note:
Unable to open file:
J:\Land Projects R2\...\align\Rd2RhsFdr\Rd2RhsFdr.vrt
I've imported the dtm before and had no problems. LD2005 wasn't open at the time and I've confirmed that there's no file locks in the LD2005 project.
Any ideas?
Michael
AEC Collection - Civil3D 2023 & Infraworks 2023
www.foxsurvey.co.nz
2 REPLIES 2
in reply to: Buzz12345
Can you import the TIN using the import command that is under the Surface pulldown menu? That option will let you navigate to the specific TIN file and open it. This will help us know if it's an issue with the surface... Thanks Dave S "Buzz123" wrote in message news:622539.1101353106646.JavaMail.jive@jiveforum2.autodesk.com... > I've encountered the following error while importing data from a LD2005 project: > ++++++++ > Error during Surfaces migration! > Please note: > plSurface->ImportTIN(J:\Land Projects R2\...\dtm\NG2000\NG2000.tin) failed! > Horizontal Alignments migration completed! > Profiles migration completed! > Please note: > Unable to open file: > J:\Land Projects R2\...\align\Rd2RhsFdr\Rd2RhsFdr.vrt > ++++++++ > > I've imported the dtm before and had no problems. LD2005 wasn't open at the time and I've confirmed that there's no file locks in the LD2005 project. > > Any ideas?
Buzz12345
Dave
The error only appears when I use a drawing based on a custom-made template and I import via the "Import from LD" command.
It doesn't appear with a default template and import from LD. It doesn't appear with the custom template and Import Tin under the Surfaces menu.
I have also found that TIN does have vertical faces - is this a possible reason for the error?
Michael
www.foxsurvey.co.nz
Rail Community
