Civil 3D Forum
import ASCIIGRID file
6 REPLIES 6
basman12
462 Views, 6 Replies
Hello everybody
How can i import ASCIIGRID file in autocad civil 3d
i use autocad civil 3d 2012.
thanks
6 REPLIES 6
Alfred.NESWADBA
in reply to: basman12
in Civil-ProjectBrowser right-click on "Surface" ==> look at the second item in your context-menu 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
basman12
in reply to: Alfred.NESWADBA
thank you for your response i do as you told me but i can't see the file.
the file extension is (.ascigrid)
thanks
basman12
sorry the file extension is
(.asciigrid)
Alfred.NESWADBA
And if it's just the extension (were I'm quite sure that ".ASCIGRID" is not a default extenstion) then try to rename your file to the extension you see in the Civil-dialog and try which one works.
- alfred -
Alfred NESWADBA
I concur with Alfred: the extension should be renamed to .ASC in order to be understood as regular Dem file.
basman12
thank you so much
i change the file extension and every thing work fine
Rail Community
