Hello everybody
How can i import ASCIIGRID file in autocad civil 3d
i use autocad civil 3d 2012.
thanks
in Civil-ProjectBrowser right-click on "Surface" ==> look at the second item in your context-menu 😉
- alfred -
thank you for your response i do as you told me but i can't see the file.
the file extension is (.ascigrid)
thanks
And if it's just the extension (were I'm quite sure that ".ASCIGRID" is not a default extenstion) then try to rename your file to the extension you see in the Civil-dialog and try which one works.
- alfred -
I concur with Alfred: the extension should be renamed to .ASC in order to be understood as regular Dem file.
