Civil 3D Forum
import ASCIIGRID file
6 REPLIES 6
463 Views, 6 Replies
Hello everybody
How can i import ASCIIGRID file in autocad civil 3d
i use autocad civil 3d 2012.
thanks
6 REPLIES 6
Alfred.NESWADBA
in Civil-ProjectBrowser right-click on "Surface" ==> look at the second item in your context-menu 😉
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
thank you for your response i do as you told me but i can't see the file.
the file extension is (.ascigrid)
thanks
sorry the file extension is
(.asciigrid)
Alfred.NESWADBA
And if it's just the extension (were I'm quite sure that ".ASCIGRID" is not a default extenstion) then try to rename your file to the extension you see in the Civil-dialog and try which one works.
- alfred -
Alfred NESWADBA
I concur with Alfred: the extension should be renamed to .ASC in order to be understood as regular Dem file.
thank you so much
i change the file extension and every thing work fine
Rail Community
