Hey, everyone,
I have a single drawing that when it is opened with regular AutoCAD (2009), it looses the imageclip every time. If it is opened with Civil 3D (2009), it's fine. I can't seem to figure out what is causing this, and was wondering if anyone else has had a similar problem. The AutoCAD machine can open other drawings without this happening, so I'm thinking it's something drawing dependent.
Audit/purge does not help.
Thanks for any help.
Solved by tcorey. Go to Solution.
Was the image originally attached using some program other than vanilla AutoCAD? Maybe there is a RegApp controlling that frame.
From the command line, type -purge -- be sure to include the hyphen -- to get the commandline version of the purge command. Use the Regapps option to delete any regapps.
It's something to try...
