Have IDSP 2014 installed on a Surface Pro Tablet w/Win 8.1 and 4GB RAM and 1.70 GHz i5 processor (64bit OS).
Running the drawing locally, but logged into the domain we have setup for the office work.
Everything working fine until we select the Points-->export-->to text file (PNEZD format). All of the interface for the eporting of points works (format and point group to use), but when we select the icon to select folder location the dialogue locks up. The drawing doesn't lock up, but the only way to get out of the export dialogue and back to the drawing is to hit ESC a couple times.
Works on all drawings and not just this one drawing.
When we try to import points it will run thru that process w/out issue.
Why is the interface on exporting locking up on this tablet?
Is anyone working with a surface tablet and Windows 8.1
I seem to think it is the update 8.1 that caused this tablet not to function properly now. Just a guess.
Any thoughts - Any ideas greatly appreciated to resolve this issue.
Solved by thejac. Go to Solution.
This sounds like rather than a lockup, you have a window or dialogue box offscreen. I have run into similar issues on laptops and the Surface Pro. Try the instructions in this link to resolve the issue:
TheJAC - The Land Group - Eagle, Idaho
Duh!
God - sometimes the obvious things are too obvious!
That was it!
Forgot this tablet had been in the office prior and had been connected to 2nd monitor!
