Civil 3D Forum
I have forgotten how to turn a polyline into a contour line.
8 REPLIES 8
Message 1 of 9
pottsk1
1590 Views, 8 Replies
I have an old AutoCAD R12 (not 2012) .dwg with polylines that have elevations on them. I have forgotten how to turn these into contour lines and build a surface out of them in 2013. I know this used to be an easy thing to do. I don't want to use the points or set up point groups in the drawing because these polylines are exactly how I want my surface to look. I need to do a plan and profile from this surface.
Thanks in advance,
Kim
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
743 Horizon Ct. Suite 100B
Grand Junction, CO 81506
8 REPLIES 8
Message 2 of 9
tcorey
in reply to: pottsk1
Hello Kim,
Create a new surface. It will be blank with no data in it.
On the Prospector tab of Toolspace, expand Surfaces, expand your new surface, expand Definition, right click Contours and pick Add...
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
AllenJessup
Off the top of my head I'd either convert them to Featurelines and add those to the Surface as breaklines. Or you could explode them and add them as lines.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 4 of 9
Jeff_M
You could use the command CONVERTPOLY to convert them to LWPolylines. But, I just found, there's no need. As Tim suggested, the Add Contours accepts both Light & Heavy polylines...
Message 5 of 9
AllenJessup
in reply to: Jeff_M
Learned something new. I never realized you could add polylines as contours.
Allen
from my nook tablet
Allen Jessup
Message 6 of 9
neilyj666
isn't a polyline with an elevation just a contour line?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 9
pottsk1
in reply to: tcorey
This is what I figured out. Thanks Tim! Thanks to everyone else who sent suggestions. I have a couple different ways to do this now.
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
Message 8 of 9
pottsk1
in reply to: tcorey
Thanks Tim!
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
Message 9 of 9
sfore
Just a suggestion to keep drawing size down.... Run the polylines through 'Drawing Cleanup' before you add them to a surface.  Often, contours/polylines from old drawings have a ton of vertices not needed.  If you run them through drawing cleanup first using simplify objects, delete duplicates and weed polylines, your surface will be cleaner and drawing size will be less.  If you do this, delete duplicates should be done first.  Simplify and weeding should be done individually - not together as a group.  Be careful with Simplify objects, because I've seen contours change shape a few times for whatever reason.  The 'weeding polylines' alone will benefit your file size.
Rail Community
