No labels about section data (section views) are displayed. The marks appears.
I import band set, all layers are activated,..
With v2012 I didn´t have this problem. In the drawing appears the labels of section data in the section views.
If I open a drawing made with V2012 in C3D 2013, those labels are displayed.
Other problem is that I can´t import styles about band set o styles data section from section view. The program say me that it can´t import those styles!! And two drawings have been made with v2013.
I have reinstalled the program(C3D 2013 with SP1) again and the problem continue.
It´s a bug of version 2013?
Thank you.
Solved by Jeff_M. Go to Solution.
Post your drawing and let one of us try it out on our 2013 with SP1.
I've found that if we use this style as default style then displays correctly.
With the command "create multiple sectionview" indicate the band set style.
Try to import styles. The styles band set or data section can´t be imported.
Nobody has seen the drawing?
I can´t show the labels (data section)
Even though the "Weeding" property has been shown in the Sectionview Bands for a number of releases, it was not used when displaying the bands until C3D2013. Your Band style has the weeding factor set to 100, changing this to 0 allows the data to display. You didn't see this issue in C3D2012 since this factor was ignored.
Not sure about the inability to import the band style or band set, looks like I can import to your drawing, and also import into another drawing from yours.
if I put the weeding factor set to 0, the labels still do not see them.
