This is a new one for me. I have some text that I want frozen in a viewport that are in a XREF. I try to freeze the layer with the lafrz command and also throught the layer properties manager and nothing happens. The text is not a part of a block and the layer is not locked. I cannot figure out why it is not working.
Any help will be appreciated.
-Daryl
Is it a Civil 3D object? Can you freeze the layer in the Xref drawing? Have the tried an Audit or Recover on both drawings?
Allen
Allen Jessup
CAD Manager - Designer
Glad you solved it. Remember to mark your post as the accepted solution to help those searching on this issue in the future.
Allen
Allen Jessup
