I have created the super elevation to my road as you can see on the attached picture, but I can't see the super elevation on my section view.
please see attached.
Was a subassembly that supports Superelevation used?
Is "Use Superelevation" set in the the Subassembly properties?
In your caption I see the Assembly type is set to "Other". Try setting it to "Undivided Crowned Road".
Now everything is good, the problem were, that I had forgotten to set the Lane super elevation, and only set the super elevation of the shoulder. see attached.
