I just don't understand the steps required to have a structure/pipe table (existing in model space) appear properly in my layout and to maintain its appearance.
If all scales are set to 1:1000 (viewport/annotative/plot/drawing) why does the text in the table appear 3 times bigger than it is supposed to be. I thought I had it figured out when I set everything to 1:1000, the table appeared the correct size in my layout. Closed the drawing and went back into it and the table is gigantic again, regen doesn't change it. I must be missing something, could someone explain how they create a structure table and have it appear to scale in their layout?
2nd part, similar issue. When I create a new viewport or do a zoom extents in a viewport I end up zoomed much further out than if I do a zoom extents in modelspace, at which point my civil labels and table are consuming the whole viewport. The viewport generally is not centered on my work area, so I can not just choose a scale and have everything appear properly. I need to manually zoom towards my work area, regen, zoom, regen etc... till I'm close. There are no objects way out in space, because as I've said I get different results doing zoom extents in model space than when in a viewport.
This all seems related to civil labels/tables. I'm sure I'm just missing/mis-using something. Why can't civil objects just be annotative, annotative objects are so much easier to use it seems. Except annotative hatches apparently screw up the undo function...
Just looking for any ideas/feedback anyone has.
Thanks!
As far as the 2nd part goes. I save a view in MS that approximates what I want in the layout viewport. Then I restore that view in the layout viewport. Then I can set the viewport to scale.
Allen
Allen Jessup
CAD Manager - Designer
On issue 2: I concur with Allen's method.
On issue 1: is it possible the drawing scale on the settings tab and the annotation scale are out of sync?
Joe Bouza
I know this might not be that much helpful, but that "civil tables" issue is consuming too much time and energy trying to figure out. Kinda glad someone out there ran into it.
Just from sorting my table-view port issue. Actually I found that in addition to having the MS & VP scaling match, you also need to appropriately size the tables when creating them in MS. I had been using the default 8.33mm size for text but when I took the scale factor into consideration and reduced it to 0.2mm, the tables worked fine and well, i happily printed my work
