Hi Ron,
We have an automated routine in RDV that should do the job for you. You can
download RDV and use that portion for free actually!
The routine I believe is called building pads. We wrote it for
visualization purposes but it should do just fine for your purposes as well.
The idea is that you select a layer which should have closed polylines on
it - typically represnting the houses that you don't want to contour through
etc... It then goes and masks/ or boundaries - I can't recall exactly each
house automatically, producing the desired effect. Whats nice about it is
that you don't have to define each area one by one - just select a layer and
go.
I'd say that it would be definitely worth a look for you. Even if you don't
buy RDV - this routine is available for free in the application.
Good Luck,
Natan
natan@rdvsystems.com
www.rdvsystems.com
Rapid Design Visualization - Visualization Made Simple
"Ron Mills" wrote in message
news:4964149@discussion.autodesk.com...
Is there any way to apply more?
The situation, I just want to break the contours at the building pads. I
really don't want to have to use boundaries, and I know it could be done
this way.
It just seems that for this instance, multiple masks would be easier.
