I'm trying to generate these reports, but the C3D 2012 does not generate at all. An error window appears with the text "The value station is out of range." And when I click on "Create Report" nothing happens ...
Someone is going through this?
I am having the same problem with C3D 2012. I have an alignment with a negative start station that I am unable to create a report for, I think this may be part of the problem because all my alignments that start at 0+000 have no problems with reports. Did you ever get this issue solved?
