Civil 3D Forum
hyperlink cursor
3 REPLIES 3
JoaoMM
173 Views, 3 Replies
hyperlink cursor
Is possible to use hyperlink cursor with osnap to use do inquiry intersection of 2 alignments??
Is possible to control hyperlink cursor because when I have a lot of alignments the monitor area is insufficient to see all Station/Offset in hyperlink cursor cursor. Is possible to hyperlink cursor showing only the 2 last aligments that i am working??
Joao
3 REPLIES 3
JoaoMM
in reply to: JoaoMM
Is possible to see station/offset of hyperlink cursor using osnap points??? I want to see a intersection of two alignments or end point of a curve. Is possible to use an "osnap" to see the exactly station and offset. I dont want to use Label to do this!!!
Joao
ACADuser
in reply to: JoaoMM
Very simple, but you must use the label command (without actually placing a label in your drawing) AND the "Magnet" option must be turned on for the AutoSnap settings (options dialogue, drafting tab).
1. From the pulldown menu: Alignments>Add Labels...
2. Click the "Add" button.
3. Select the alignment that you want the station and offset to reference.
4. Move your cursor near the point you want to snap to (make sure your osnap is set accordingly) and the cursor will magically move to point you wish to query. The station and offset are displayed near the cursor.
TIP: If your hands are very shaky just let go of the mouse after is "magnetizes" to the osnap point.
When done just right-click to end the command without placing a label.
HTH
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
JoaoMM
in reply to: JoaoMM
Thanks HTH!!! It helps me a lot! 🙂
Is possible to do something similiar but with my finnished ground in profile view.
Is any manner to list/ or to see in hyperlink cursor elevation of finnished ground in a specified station.???
Example:
I want to see the elevation on Km 0+554,513 of Finnished Ground of Road 2???
JoaoMM
Rail Community
