Civil 3D Forum
Hydraflow- Import pipes all 12"
10 REPLIES 10
Message 1 of 11
882 Views, 10 Replies
Help-
When I import my hydraflow xml file into C3D 09 all the pipes come in 12" and all the structures come in as the first in the parts list as well. Then when I try to swap the part on any of the pipe segments or the structures there is nothing in the list. I know they are in the parts list because I originally drew the layout in cad then exported it to xml file to design, size, ect. in hydraflow and i can still see them in the parts list in the settings. Any help would be greatly appreciated. Thanks
Katie
10 REPLIES 10
Message 2 of 11
nevermind i got it
Message 3 of 11
Matt.Anderson
For those who stumble upon this question:
The answer is that today, the LandXML import used the Standard Part List for the creation of the pipes.
The workaround is to reset the parts list for that network before you swap your parts.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 4 of 11
Thanx. 🙂
John Mayo, PE
Project Engineer
Conklin
Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2
GB Ram
Nvidea Quadro FX w/ 128 MB Ram
For
Message 5 of 11
Were you able to import and export using custom styles?  I am still having this problem as every pipe imported is 12" and structure styles are not correct.  When I import the network it changes the style to a default network style, but not the Standard style.
Message 6 of 11
Matt.Anderson
Jason -
You will need to set the correct style in the Part List.
Product Manager
Autodesk (Innovyze)
Message 7 of 11
in reply to: Matt.Anderson
Thanks Matt, looks like that will fix it.  One more question - will Hydraflow always default to RCP? Is there a way to get it to use PVC/other pipe materials?
PS I worked at JAS in '04 and '05, would you happen to be the Matt Anderson that was there?
Message 8 of 11
Matt.Anderson
Jason -
Yes, I am that Matt Anderson.
As for Hydraflow default - the only number it knows is the Mannings value.  Your parts in Civil 3D should have the appropriate Mannings value based on the material you are using.  Those Mannings values are transferred to Hydraflow and SSA via the STM file.
Product Manager
Autodesk (Innovyze)
Message 9 of 11
Joe-Bouza
Pardon My density, but how does one reset the part list, and what do you mean by before swapping parts? I want storm sewers and c3d to swap the parts on update, no?
I see I can edit standard to include my other required pipe size. Does the work-around allow for my own partlist?
Joe Bouza
Message 10 of 11
Matt.Anderson
in reply to: Joe-Bouza
Joe -
Prior to importing your storm sewer design, you want to check the following:
1. Parts List that contains your parts.
2. Command Settings for ImportStormSewerData
a. Part matching Defaults
b. Part List used
c. For 2012 ONLY Allow Part Family Swapping & Use Imported Part Id for Part Family.
Those two later item provide an additional level of control not available in 2011.
Product Manager
Autodesk (Innovyze)
Message 11 of 11
Thanks Matt, I keep those tips on the top of the pile. Smiley Very Happy
Rail Community
