hallo,
I have questions.....
In my c3d, there are channel and roadways corridor and I want to view it on 3d. How they are looked in real condition (with existing surface).
I had tried to access it using object view, but I cannot see that corridor cut the surface (the corridor is under the surface). So, how i can look my surface cutted by the corridor?Or any mistake or there need any setting to view it?
thanks before,
Solved by mathewkol. Go to Solution.
Matt,
I have got my existing surface is cut by the corridor surface. And if I want to view the cut surface (compile surface) with corridor in 3d, how can I do it, i have to select both 2 object (compile surface and corridor) or it can be seen automatically (how I can set it)?
Another question, how about view the building pad grading?
How I apply it in the surface?
I have building pad grading, but i cannot view it applied on the surface. Meanwhile, I want to view the building pad together with the corridor (look at all the site together).
Thanks before,
