Would you please post a sample of the data you have so we can see how it's laid out. Also, what format is it in? A TXT file?
Allen Jessup
Allen Jessup
CAD Manager - Designer
Given a horizontal angle, a horizontal distance and a delta elevation then it should be possible to create an FBK file which Civil3d can read and use to create survey points. From there it would be fairly simple to build a topographic surface.
We need to see a sample of the data to answer further.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
sboon wrote:create an FBK file which Civil3d can read
Unfortunately the OP's using LDD, not Civ3D...
If I recall correctly Land Desktop can import and process FBK files also.
Allen Jessup
