I do not see an image, but I understand your question. Let me try to
explain what is going on. In Civil 3D, there is a live topology model which
is dynamically updated when you make edits to objects. The Alignments and
Parcel Segment lines are two of the Civil 3D objects which participate in
the topology. When you create a Site, that is really a collection of
objects which will be in the same Topology. Objects which are in different
Sites do not interact with each other. You can illustrate this by creating
a simple closed parcel in Site 1, and then create an Alignment in Site 2,
which splits the parcel. You will see that the parcel is not impacted.
If you create the Alignment in Site 1, you will see that the parcel is
split. Now if you make geometric edits to the alignment, the parcels will
reflect those changes.
In your case, it sounds like you only have Alignments in your drawing.
Since Alignments are managed as part of a Site, if 2 alignments are in the
same Site, and they form a closed area, a "parcel" will be created. To
prevent "parcel" from being formed, you can put the alignments in different
Sites. To do this, create a new Site on the Alignment Creation dialog and
use that for the new alignment. If you are creating Alignments which are
duplicate (or near duplicate), I would recommend putting them in different
Sites.
As an alternative, you can allow the parcels to be formed and hide them from
display. I think Kevin's suggestion is the best approach for that. If you
put the Aecc_Parcel on a layer, you can freeze that layer.
I did find a defect with the default layer when the parcel is formed by
alignments. If you go to the drawing settings (rt. click on the drawing ->
Edit Drawing Settings....) you will an Object Layer Tab - this is used to
set the layer for newly created objects. I did find that this layer is not
being applied if the parcel is formed by closed alignments. We will get
that resolved. Another way to "hide" those parcels is to set the parcel
label visibility to false. If you have no other parcels in your drawing,
one easy way to do this is to go to the Parcel node in the Settings Manager,
rt. click, Edit Label Style Defaults..... In the next dialog, expand the
Labels category and set the visibility to false.
Daniel Philbrick
Civil 3D Development, Autodesk, Inc.
wrote in message news:4987127@discussion.autodesk.com...
IF you look at the pic I attached...I have several "interior" lots..... IF I
CORRECTLY create an alignment it AUTOMATICALLY creates a parcel.....I refer
to this as a phantom parcel......How do I prevent this???....
I know I can stop short 2 tenths, hand draft and account for in the design,
but this causes alot of extra work!!!!! I can't always assume that others
involved in drafting and design will account for this......it causes alot of
surplus drafting, turning labels off, etc......why isn't it accurate or
allowed?....
