Member
metchebes
Message 1 of 8 (267 Views)
How to slice a 3D raster surface ?
267 Views, 7 Replies
07-04-2012 12:55 AM
Hi
I created a 3D raster surface from point cloud using create from point cloud tool ( Planning and analysis workspace, create tab). Now I would like to cut/slice this surface to be able to offset one part related to the other.
Does anyone knows how to do it? I tried with the slice tool but I can only select the object and after nothing happens.
thanks a lot in advance
Alfred.NESWADBA
Message 2 of 8 (266 Views)
Re: How to slice a 3D raster surface ?
07-04-2012 12:57 AM in reply to: metchebes
add a new boundary to the current surface.
- alfred -
Alfred NESWADBA
Member
metchebes
Message 3 of 8 (265 Views)
07-04-2012 12:59 AM in reply to: Alfred.NESWADBA
I need more details :smileyhappy: I m new user
Alfred.NESWADBA
Message 4 of 8 (262 Views)
07-04-2012 01:17 AM in reply to: metchebes
does this help?
Create a closed polyline, then go to the Civil3D-projectbrowse, find your surface, go to the edits for your surface and add the new polyline to the borders.
- alfred -
Alfred NESWADBA
antoniovinci
Message 5 of 8 (261 Views)
07-04-2012 01:52 AM in reply to: metchebes
What do you mean with "3D raster surface", sir?
A 3D surface may only be vector, so if you wanna slice it, you first have to solidify it.
Member
metchebes
Message 6 of 8 (256 Views)
07-04-2012 03:46 AM in reply to: antoniovinci
So it's in planning and Analysis workspace and I did like this http://www.youtube.com/watch?v=GZj4nHpcMDw
antoniovinci
Message 7 of 8 (254 Views)
07-04-2012 04:01 AM in reply to: metchebes
Well, in that video he generated a raster Dem file, which you can stylize but not edit in Autocad environment.
Again, if you'd like to slice, trim, hole and whatever else a surface, you gotta first create it as a vector one, then explode it twice, solidify it, and finally you can edit it as a thin solid.
Alfred.NESWADBA
Message 8 of 8 (251 Views)
07-04-2012 04:31 AM in reply to: metchebes
you have Civil3D, then you can create a Civil3D-surface based on the pointcloud and that can be limited to any area defined by poly like I showed in the video.
Also you mentioned that you like to "offset" anything. I agree also to antoniovinci that you will first have to get a vector-format to be able to use offset-command(s).
- alfred -
Alfred NESWADBA
