Currently using civil 3d version 12 with service pack 2 on windows 7.0 pro. I have been trying for awhile to see if this can be done but I don't think so.
Here is what I would like:
I create my cross-section with no problems. I have created my sample lines and multiple section views, sheet borders,volume take offs and section view groups and a material list. Instead of place my quantities on a drawing area in a tabular format I would like to place them on the individual cross-sections and have them dynamically updated.
Can some show me some step by step on how to do this.
Start by opening the tutorial drawing Sections-Data-Band. Use the Compute Materials command to generate some earthwork volumes so that you have something to display. Right-click one of the section views to open the properties dialog and switch to the Volume Tables tab. Adding a table is similar to data bands. You can also open the properties of a Section View group and add tables to all of them.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
