how do I set C3D so that the Task Panel does not display by default when startup? Annoying as hell. tried alread colsing it ans saving Profile. I remember that there used to be a box to check under options tabs but cannot fid it.
Hopefully your C3D workspace does not have it and you can change workspace to your c3d one.
If changing workspace does not work use "MAPOPTIONS". Task pane tab and to the right you will find the turn off task pane.
