Has anyone tried rubber sheeting a pdf with 2014? It now asks you yo select an image. Since a pdf is not an image not sure how to accomplish this. WHY DID THEY CHANGE THIS?
thanks,
Jason
what version of RasterDesign had the aibility to rubbersheet a PDF? I don't know any, imho it always used only rasterfiles.
Or do you speak about command _ADERSHEET for previous versions?
Another option: convert your PDF to a rasterfile, then you can use RasterDesign to rubbersheet it.
- alfred -
Alfred,
You just answered my question - it is a problem with a Raster command (IRSHEET) getting mixed with _ADERSHEET. I only used Civil 3D/Map 3D for rubbersheeting, never had Raster Design until now. I just checked and sure enough, Autodesk repalced the tired, true and versatile _ADERSHEET in Civil.cuix with useless IRSHEET. Typical.
Thanks for the help.
Jason
neilyj (No connection with Autodesk other than using the products in the real world)
Your method works fine for linear scaling, but often I need 3 or 4 points to get an accurate geodetic fit. I work in large areas.
Your suggesstion sounds like a lot of work. And no, my method is not inaccurate. I know my data.
I solved this problem by going into the CUI and changing the command syntax from the useless Raster to tried and true Map 3D method. Back to being efficient.
