New Member
0 Kudos
Post 1 of 5
How to rotate point labels on an elevation (facade) drawing?
274 Views, 4 Replies
12-07-2012 12:43 PM
Is it possible to rotate the point labels when working with point files from an elevation Survey in Ciivil 3D? When activating the labels visibility they are horizontal, but when I rotate the drawing  to a side view I am can´t see them.
So far I was working with Autocad (importing a dxf). Is there a way to rotate at the same time all the points labels, wich in this case are just text items?
Thank you
It's under the General tab in the point style.
*Pro
49 Kudos
Post 2 of 5
Re: How to rotate point labels on an elevation (facade) drawing?
12-07-2012 12:51 PM in reply to: rigoleto
set your point lables to rotate to view instead of object?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
New Member
0 Kudos
Post 3 of 5
12-07-2012 01:04 PM in reply to: dgordon
 I didnt know I could do that. I guess it is on the menu where you activate and deactivate the labels visibility, isnt it?
Thank you!!! It will be so helpful
169 Kudos
Post 4 of 5
12-07-2012 01:44 PM in reply to: rigoleto
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
267 Kudos
Post 5 of 5
12-07-2012 07:12 PM in reply to: rigoleto
If I remember correctly (don't have C3D on this computer) the default point styles that ship with C3D have the label component visibility toggled off in the model view.
Double click a point style (not label style) in your settings tab and go to the dsiplay tab. Select the pulldown near that top and change the view to model. Is the label component toggled on or off?
Brian Hailey
CAD-1.com
My Blog
