How to re-create contour lines from an existing contours.?
I know there is an option to create contours from 3d lines, 3d points etc… but I have a contour, got from someone else, it is completely made of curves. How to recreate this type of contours, is there is any option in civil 3D to create this type of contour lines? (curve contour lines) also those contours are given in 2d only. any way to make them in 3d lines? Please help.
(.dwg attached)
Have a look at this thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/SURFACE-TRIANGULATION/td-p/4842299
Is there any way you can get your hands on the surface data that was used to create the contours? (assuming it was done in a modeling app like C3D or InRoads). My first choice would be the breaklines and points. Second choice would be triangles. Way down the list would be contours -- but yes, there is an import contours tool. But they'd have to be at the appropriate elevation -- otherwise how would the import contours tool know what elevations they belonged at?
As far as the contours being 2d goes, a contour can ONLY be at one elevation so 2d polylines are fine. But you could move each contour to the appropriate level.
Don Ireland
Engineering Design Technician
Thanks for your reply sir
but i am not happy with your answer, becauce i am working on a very big project, it dos't make sense to give elevations on eatch contours may be it is 1000nds of contour line. and this is a proposed grading contour so no way to get that surface data that was used to create the contours, how it becomes arc any option in C3D?
sir
it works only for converting that arc lines as polylines or lines , how you elevated that lines to the correct elevation, giving the elevations of eatch polylines one by one ?
@dilsmails wrote:
sir
Yes I did because it was a small sample and it only took about 2 minutes to modify them.
If you are working on a larger set, this lisp routine should help: http://cadtips.cadalyst.com/object-properties/auto-elevate-polylines
its not working
Command: AUTOELEVATE
Enter starting radius:1
Enter radius increment:1
Enter maximum radius:2
Process Complete...0 Flat Segments Elevated.
Command:
I can't get that lisp working either, it throws up an error:
; error: ActiveX Server returned the error: unknown name: Elevation
I think the fact that they are arcs is a red herring - you can convert arcs to polylines and use those as breaks.
I think manually adding the elevations is the best, if not the most ideal, option.
Plus, even if the lisp did work, there are a lot of contours in this sample that aren't labelled so you'd have to do a lot manually anyway.
Sorry!
Kevin
@dilsmails wrote:
its not working
If I remember correctly, your 'contours' were arcs. The lisp routine elevates polylines, not arcs.
Convert the arcs to polylines and it runs fine, except as Kevin pointed out, on contours with no elevation text.
Here is a view of the site tilted almost on its side, showing the elevation applied to most of the contours.
That took about 1 minute. There is no magic button if that is what you're looking for. You'll have to put a little manual effort into this one.
but somebody is worked with me, they converted the 2d contours ( already uploaded a part of it) to 3d very simply. but they are not telling how the did. any ides's?
