Civil 3D Forum
How to multicolored polylines
15 REPLIES 15
Message 1 of 16
4131 Views, 15 Replies
Hello every body!
i want to make a multicolored polyline with all the function, i try to use MLSTYLE command but it dont help so much because i can not draw a curve or i can not add vertex after the draw , any another suggestion.
thanks
15 REPLIES 15
Message 2 of 16
do you have an example of what a multicolored polyline is? would the polyline look like a rainbow was being draped over it? it seems to me once a polyline is created it can be broken at points where you want to change from one color to the next.
Message 3 of 16
thank you for response
i need to draw a polyline consist of two colors Instead of one color is there is any way to do that direct from polyline command?
i try to use MLINE command and it seems good but the polyline was  without curves .
Message 4 of 16
check the picture below
Message 5 of 16
antoniovinci
Are you talkin' about something like this..?
Message 6 of 16
I just want to create style for a polyline that instead of one color i can choose two colors without explode it or offset it,
i tried MLSTYLE commande but it wasnt so good .
is anybody tried another method ?
Message 7 of 16
jmayo-EE
in reply to: antoniovinci
Pretty cool Antonio. You gonna' share? 🙂
John Mayo
Message 8 of 16
AllenJessup
AFAIK that's not possible. If you set WHIPARC to 1. All of the arcs will plot the layer color and the lines will take the color from the plot style. But that effects every single polyline and isn't what you're looking for. It looks like (to me) that you'll have to stick with your workaround.
There may be something that could be done with a non-lightweight polyline with some programming. But that's way past me.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Message 9 of 16
antoniovinci
in reply to: jmayo-EE
johnm wrote:
You gonna' share?
Well, I belong to the "old school", sorry.
I mean that in this current life I'm (still) hetero, Johnny.
In the next one, who knows..?
Message 10 of 16
jmayo-EE
Only asking because I'm impressed with the CAD work. I'm just a geek. 🙂
John Mayo
Message 11 of 16
antoniovinci
All right, JM, I was joking...
Now check this out (I used my national flag's colours) closer to the OP request:
I attached the .DWG file, now you can guess how I did it: have fun !
Message 12 of 16
jmayo-EE
Thanks!
John Mayo
Message 13 of 16
jmayo-EE
190 something objects. I thought you had something real geeky up your sleeve. 😉
Here is a 3 object version that is still not what the OP needs but the inner geek is getting out. 🙂
John Mayo
Message 14 of 16
antoniovinci
Your continuous rail on background is a winning idea, Joe.
Get an advice: before you share a DWG with others, please purge it, because of the bunch of unused SHX files.
Message 15 of 16
Thanks all for response
Message 16 of 16
Joe-Bouza
in reply to: AllenJessup
Maybe not with a polyline but two alignment styles and a zero offset alignment can accomplish this Smiley Wink
Joe Bouza
Rail Community
