I used to work with position of command line at the bottom of the screen, but recently it moved to the upper left corner of screen.
I have followed suggestions from threads in forum but the result is same, command line position didn't change.
Can some one provide me information how to move command line to the bottom of the screen?
Thank you in advance.
Solved by ToddRogers-WPM. Go to Solution.
R,
You should be able to grab the grey bar to the left and move it anywhere you want. Also, click the wrench for options on customizing the command line.
Dave
Dave Stoll
Las Vegas, Nevada
Thank you for prompt reply.
I have followed all suggestions but my command line position still same in the upper left corner of my screen.
Below are briefly explanations about the command line:
1. It only appears on screen when I type something
2. No "wrench" icon
R,
Can you post a Screen Shot or Sample Drawing?
Dave
Dave Stoll
Las Vegas, Nevada
I wrote a blog on something similar to this. This will walk you through the steps to fix this from the CUI...
http://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
I had same problem, but i could solve it by this link. Please follow this: https://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
