KIndly Help Me
I have this corridor that has a typical "U-ditch" subassembly attached to its Assembly.
I have already created a corridor surface and used a Datum links as its data.
The problem is that when i generated the x-section, the corridor datum surface section (violet/magenta) are not all attached to the datum links.
I already reviewed the assembly and confirmed that the "U-ditch" has datum links in it.
you can view the attached pic.
Solved by NathanBee. Go to Solution.
