stgospel
Message 1 of 4 (1,355 Views)
How to make the Corridor Datum Surface to attach itself to all Datum Links
1355 Views, 3 Replies
05-12-2011 11:39 PM
KIndly Help Me
I have this corridor that has a typical "U-ditch" subassembly attached to its Assembly.
I have already created a corridor surface and used a Datum links as its data.
The problem is that when i generated the x-section, the corridor datum surface section (violet/magenta) are not all attached to the datum links.
I already reviewed the assembly and confirmed that the "U-ditch" has datum links in it.
you can view the attached pic.
In the Surface tab of Corridor properties, have you changed the Overhang Correction to 'bottom links'?
I've seen examples on this DG of that correcting this problem before.
Distinguished Contributor
NathanBee
Message 2 of 4 (1,349 Views)
Re: How to make the Corridor Datum Surface to attach itself to all Datum Links
05-13-2011 01:59 AM in reply to: stgospel
stgospel
Message 3 of 4 (1,345 Views)
05-13-2011 02:13 AM in reply to: NathanBee
Thank you very much !! Ive been Using Civil 3d for 3 yrs now and i can't believe i forgot that.
NathanBee
Message 4 of 4 (1,336 Views)
05-13-2011 03:06 AM in reply to: stgospel
No worries mate. Glad to have helped. :smileyhappy:
