Civil 3D Forum
How to make the Corridor Datum Surface to attach itself to all Datum Links
3 REPLIES 3
stgospel
2395 Views, 3 Replies
KIndly Help Me
I have this corridor that has a typical "U-ditch" subassembly attached to its Assembly.
I have already created a corridor surface and used a Datum links as its data.
The problem is that when i generated the x-section, the corridor datum surface section (violet/magenta) are not all attached to the datum links.
I already reviewed the assembly and confirmed that the "U-ditch" has datum links in it.
you can view the attached pic.
3 REPLIES 3
NathanBee
in reply to: stgospel
In the Surface tab of Corridor properties, have you changed the Overhang Correction to 'bottom links'?
I've seen examples on this DG of that correcting this problem before.
Tags (1)
stgospel
in reply to: NathanBee
Thank you very much !! Ive been Using Civil 3d for 3 yrs now and i can't believe i forgot that.
NathanBee
No worries mate. Glad to have helped. Smiley Happy
Rail Community
