We are making road , it has intersections with simple roads wich leads to forest or a fields or to a private territory. We have 60 of those intersections (crossroads) , if we would start making them all with intersection wizzard it would take a lot of time... , maybe there is simpler way to make such an easy crossings ? ( all of those crossroads are same type same geometry, the only difference is location)
If all of the intersections are the same, with comon assemblies and settings for crossfall etc then you should be able to preset most of this stuff so that when you run the Intersection wizard you can just skip through all of the pages without changing anything. Should be less than a minute for each one.
I would caution however against trying to build 60 intersections in a single drawing. The number of alignments, profiles and other data could easily bog down your system to the point where the drawing in unusable. You should think about breaking up the design into manageable pieces; this leads to another advantage where you can get multiple people working on those intersections at the same time.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Mainly its for visual presentation . I will paste sketch to show how my model looks in plan. I need to make this road 3d with all sideways . Ofcourse it would be rly cool if it coud evaluate materials used to build
