I created a profile in the profile view using the profile creation tool. I have two main problems that i am not sure how to solve:
1. I am trying to create a pipe from the profile I created, but i am not sure how. I created the profile as the center of the pipe.
2. On the same aligment i created the profile, i sampled the aligments. In the section view i do not see the profile i added im the profile view.
how can i add the profile to show in the section view?
Thank in you in advance.
Solved by Joe-Bouza. Go to Solution.
in the create design panel of the home tab>> feature lines >> create from alignment>> choose your layout profile> clear the dynamick link box. Now you have a FL you can use to create pipe network from object. read the prompts and dialog to suite your needs.
Joe Bouza
