Show only
Search instead for
I want to label a line using the /label/add dynamic label command. I want it to output "azi-distance " but it only labels the line with "N xx.xx E" not DMS. I can't seem to find an option that will give DMS. on top of that, the direction is wrong. it always gives direction in respect to the x-y azis and not the orientation that I setup in /project/drawing setup. Strange thing is that if I check the direction in /inquiry/line command it comes out correct as I set it up but in the label command it's always wrong.
I previously used 2002 and had no problems with this command.
