Civil 3D Forum
How to label ditch slope?
4 REPLIES 4
511 Views, 4 Replies
How do you label the foreslope and backslope of a section? For instance 3:1...
4 REPLIES 4
troma
Does the section segment slope label express as a Run/Rise or Rise/Run?  If it's not the way you want it, you may have to make an expression for it.  Then just add the text ":1" after if in the label style.
Mark Green
Working on Civil 3D in Canada
david.zavislan
If the slopes are part of a corridor section, you can apply slope labels to links, based on their code names, in the assigned code set.
David Zavislan, P.E. | Wood Rodgers, Inc.
in reply to: david.zavislan
OK, thanks.
Joe-Bouza
Is this a corridor or surface section? If its a corridor, look into the codeset for that link
Joe Bouza
Rail Community
